Canman93
Jan 12, 2021Aspirant
Orbi RBK753S and desktop pc connectivity problems
Model is Orbi RBK753S I recently installed the Orbi Mesh in my house and almost everything has been flawless. The only problem I am experiencing is with my desktop pc. I have connectivity problem...
Jan 12, 2021Guru - Experienced User
Is Armor enabled on the RBR?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Canman93 wrote:Model is Orbi RBK753S
I recently installed the Orbi Mesh in my house and almost everything has been flawless. The only problem I am experiencing is with my desktop pc. I have connectivity problems every time on start up and have to run the troubleshooter which comes up with no detected problems. After connecting, disconnecting wifi, running the troubleshooter and pulling my hair out it oddly connects with intermittent connections; it stalls for short periods and disconnects altogether. After running a speedtest I am also only getting less than 40% of total bandwidth; 90 v 240
Funny enough my connection disconnected while typing this message. The wifi connection, although connected, said can't connect to this network and the error message was ERR_INTERNET_DISCONNECTED. Then poof it starts working again....
This is my work computer and essentially the most important piece in the entire house.
* The router is located in the room directly below my desktop pc
* Wifi - Broadcom 802.11ac Network Adapter - latest driver / no conflicts
* Bitdefender Total Security (if this matters at all)
* Spectrum Internet / Modem only; no double NAT
Canman93
FURRYe38 wrote:What Firmware version is currently loaded?
The firmware was updated on setup a few days ago and running Firmware Version V3.2.16.22_1.4.9
Yes Armor is enabled
House is 4800 sq ft. The router is in the basement on one side of the house, satelittle 1 is on first floor on opposite side and satelitte 2 is on second floor on the respective opposite side of floor 1 or two floors staright up from router. Coverage throughout has been great. My office is on first floor and located directly above router and connected to it.
Is this all good?
