Canman93
Jan 12, 2021Aspirant
Orbi RBK753S and desktop pc connectivity problems
Model is Orbi RBK753S I recently installed the Orbi Mesh in my house and almost everything has been flawless. The only problem I am experiencing is with my desktop pc. I have connectivity problem...
Canman93
FURRYe38 wrote:What Firmware version is currently loaded?
Is Armor enabled on the RBR?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
The firmware was updated on setup a few days ago and running Firmware Version V3.2.16.22_1.4.9
Yes Armor is enabled
House is 4800 sq ft. The router is in the basement on one side of the house, satelittle 1 is on first floor on opposite side and satelitte 2 is on second floor on the respective opposite side of floor 1 or two floors staright up from router. Coverage throughout has been great. My office is on first floor and located directly above router and connected to it.
Is this all good?
Jan 12, 2021Guru - Experienced User
Basements are not recommended places for wifi routers. 1st floor is recomended or 2nd level. You can put RBS in the basement.
I have mine on 2nd level and 1 RBS on 1st floor and 1 in the basement here.
- Canman93Jan 15, 2021Aspirant
FURRYe38 wrote:Basements are not recommended places for wifi routers. 1st floor is recomended or 2nd level. You can put RBS in the basement.
I agree but I'm pretty much stuck everything feeds into my storeroom in the basement. I have been trying to figure out how to get the coax into my office which is located directly above and would be the best location for the router. The only outlets in my office are electrical and don't want to random start drilling into my walls.
