Canman93
Jan 12, 2021Aspirant
Orbi RBK753S and desktop pc connectivity problems
Model is Orbi RBK753S I recently installed the Orbi Mesh in my house and almost everything has been flawless. The only problem I am experiencing is with my desktop pc. I have connectivity problem...
Jan 12, 2021Guru - Experienced User
Basements are not recommended places for wifi routers. 1st floor is recomended or 2nd level. You can put RBS in the basement.
I have mine on 2nd level and 1 RBS on 1st floor and 1 in the basement here.
Canman93
Jan 15, 2021Aspirant
FURRYe38 wrote:Basements are not recommended places for wifi routers. 1st floor is recomended or 2nd level. You can put RBS in the basement.
I agree but I'm pretty much stuck everything feeds into my storeroom in the basement. I have been trying to figure out how to get the coax into my office which is located directly above and would be the best location for the router. The only outlets in my office are electrical and don't want to random start drilling into my walls.
