orbifill's avatar
orbifill
orbi rbk753s auto firmware update v3.2.16.6
Recieved firmware update v 3.2.16.6 several days ago.  As I look at the nomenclatures for firmware updates they indicate a different number v 3.2.15.32 HOT FIX for the RBK753S while the v 3.2.16.6 is...
  • FURRYe38's avatar
    Aug 29, 2020
    All models have the same FW version.
    Sometimes a reset and setup from scratch is needed after a FW update if problems are experienced..
    No.
