orbifill
Aug 29, 2020Aspirant
orbi rbk753s auto firmware update v3.2.16.6
Recieved firmware update v 3.2.16.6 several days ago. As I look at the nomenclatures for firmware updates they indicate a different number v 3.2.15.32 HOT FIX for the RBK753S while the v 3.2.16.6 is...
- Aug 29, 2020
All models have the same FW version.
Sometimes a reset and setup from scratch is needed after a FW update if problems are experienced..
No.
orbifill
Aug 30, 2020Aspirant
thanks furrye38
Even though accepting as solution now, would still like to be able to turn off auto updates so it doesn't bring system down at a crucial time of use in today's work from home environment. Thanks again for response.
Aug 30, 2020Guru - Experienced User
You and everyone else who owns Orbi since the beginning. NG doesn't seem to want to provide that feature. Most of the time FW updates are notifications about minor updates which are user allowed updates so you have a choice here. Any Major version updates NG likes to be able to push these.
Good Luck.
