Shadowgent
Aug 09, 2020Tutor
Orbi RBK753S AX4200 - Nest Thermostat Battery Drain
Installed new system a couple of weeks ago, and Nest thermostat keeps disconnecting from network due to battery drain. I had other ax and wifi 6 systems and never had this issue. Is there a fix in ...
Chris-Chapin
Jan 16, 2021Initiate
Identical issue with my newly installed Orbi AX4200 system. I have 3 Nest Gen 3 Thermostats that have worked fine for the past 3-4 years on my Xfinity Gateway. Once I installed the Netgear Orbi AX4200 system, all three Nest Thermostats have experienced battery drain issues (not using a C wire on Thermostat) that results in them dropping Wifi connection. All three were connected via 5GHZ channel. I have since set up a separate wifi network using the older Xfinity Gateway’s 2.4GHZ channel with a different SSID to connect the 3 Nest Thermostats. All 3 Thermostats are again working fine. Running two different WiFi networks in my house is really not ideal, but is the only way I could get the Nest Thermostats working correctly. Would really like either Nest or Netgear to come up with a fix for this issue.
Terry8166
Feb 07, 2021Aspirant
i have a nest thermostat Gen 3 that has worked for 1,5 years on google wifi router and erro router. this week iinstalled the orbi rbr750 ax4200. i am very plesed with the speed and stability of this router. However there is one major issue that i see many wiht this router having OFFLINE LowBattery. I just wanted to add my voice to the choir, I am very frustrated with this issue. This is not a cheap router and i would expect better support form netgear on this issue. Yes i have a ticket open. The only way i have been able to solve this issue was to connect my Google wifi as a stand alone connection for my nest thermostat. no more low battery issues.
The good news is i got this router form Costco and i will retrum it an try our a different Wifi 6 router if netgear cant get this issue fixed.
- FURRYe38Feb 07, 2021Guru - Experienced User
What FW version is currently loaded?
What FW/SW version is loaded on your NEST controllers?
What is the distance between the RBR and RBS?
What is the distance between the RBR/RBS and NEST controllers? In Feet please.
What is the CTS value your using on the RBR? Under Advanced Tab/Advanced Settings/Wireless Settings
Please review this and give a try:
FYI, I'm on v12 with my 8 series and 2 RBS. Using manual channel 1 and 40. CTS at 64. I have not seen any issues with my 1 3rd gen NEST since last year.
Also please open a support ticket with NEST and NG regarding this.
Terry8166 wrote:i have a nest thermostat Gen 3 that has worked for 1,5 years on google wifi router and erro router. this week iinstalled the orbi rbr750 ax4200. i am very plesed with the speed and stability of this router. However there is one major issue that i see many wiht this router having OFFLINE LowBattery. I just wanted to add my voice to the choir, I am very frustrated with this issue. This is not a cheap router and i would expect better support form netgear on this issue. Yes i have a ticket open. The only way i have been able to solve this issue was to connect my Google wifi as a stand alone connection for my nest thermostat. no more low battery issues.
- Terry8166Feb 08, 2021Aspirant
HI @ FURRYe38,
See the answers to your questions below.
ONT P/N3FE56389ABBE
V3.2.16.22
6.1-9
25 feet
12 Feet
64
Open Case number 44131326.
BTW I have connected the nest wifi to a google wifi puck that is next to the orbi. The google WIFI has a different SSID and has been connect for more than 24 hours. The battery voltage on the nest has increased form 3.7 to 3.88 volts. This indicates that the nest battery is able to charge when it is not connected to the ORBI…When connected to the orbi you can see over the course of 2 – 3 hours the battery drops until it goes below 3.6V..at which point you get an OFFLINE low battery fault on the nest.
Let me know if you need any additional information or any suggestions. Glad to see that your system is working but i can see a number that are not.
thanks again for your help....hope to get some form netgear too.
