Shadowgent
Aug 09, 2020Tutor
Orbi RBK753S AX4200 - Nest Thermostat Battery Drain
Installed new system a couple of weeks ago, and Nest thermostat keeps disconnecting from network due to battery drain. I had other ax and wifi 6 systems and never had this issue. Is there a fix in ...
Terry8166
Feb 08, 2021Aspirant
I used your suggestion, connected my old mesh router (google wifi using just one puck) problem solved. But not really. The kind of money i paid this should not be an issue.
Feb 08, 2021Guru - Experienced User
V3.2.16.22
There is newer v12 FW available:
What is the distance between the RBR and RBS?
25 feet
This is too close between the RBR and RBS. 30 feet or more is needed.
What happens if you turn OFF the RBS and connect the NEST to the RBR while RBS is turned OFF?
Terry8166
