Harry_CSLCV
Jul 03, 2021Aspirant
Orbi RBK753S AX4200 Wi-Fi 6 Mesh Router Not Connecting to internet (Cox FO business)
I am looking to replace an existing Nighthawk wifi router with the Orbi RBK753S AX4200 Wi-Fi 6 Mesh Router with Two Satellites at my place of business. The internet connection is a Cox business conne...
- Jul 10, 2021
Glad you figured it out.
Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemPlease mark your thread as solved so others will know.
Enjoy. :smileywink:
Jul 03, 2021Guru - Experienced User
Orbi 7 series is mostly meant for home and small office environments. May not work well in business environments.
- Harry_CSLCVJul 10, 2021Aspirant
Hello Furrye38
Thank you for your reply. Further trouble shooting led to seeing that the 'output' from the Cox 7210 SAS (service access switch) was essentially an ethernet LAN, so once the Orbi was confiured as an access point as opposed to a router, everything came up.
All the best,
Harry
- FURRYe38Jul 10, 2021Guru - Experienced User
Enjoy. :smileywink:
