mbailey555's avatar
mbailey555
Orbi RBK753S cannot obtain IP address
Last year I purchased the Orbi RBK735S wifi router and the Nighthawk CM1150V modem with Xfinity (Comcast) as my ISP. I have a smart home with Alexa and 40 devices (Kasa switches, Roku TVs, Android pho...
  • CrimpOn's avatar
    CrimpOn
    Feb 06, 2023
    At the bottom of the list of available WiFi systems, my Android phone has an option to "Add a Network".
    What happens when you select that option and manually enter the correct WiFi SSID/password?
