mbailey555
Feb 06, 2023Aspirant
Orbi RBK753S cannot obtain IP address
Last year I purchased the Orbi RBK735S wifi router and the Nighthawk CM1150V modem with Xfinity (Comcast) as my ISP. I have a smart home with Alexa and 40 devices (Kasa switches, Roku TVs, Android pho...
- Feb 06, 2023
At the bottom of the list of available WiFi systems, my Android phone has an option to "Add a Network".
What happens when you select that option and manually enter the correct WiFi SSID/password?
mbailey555
I tried resetting the router to factory settings and setting it up as a new network. I recreated the same network name as had previously existed with the same password and all my devices immediately connected. I still have no idea why the restart that occurs when power is cut off and restored causes device connections to fail because of an inability to get an IP address but I'll try to figure that out later. However, I ran into another strange situation. My phone was connected to the new network but the list of wifi networks contained a second entry with same network name with a label stating "Available via Orbi." I figured this was left over from the previous network of the same name so I selected the entry with the intention of forgetting it. The only option when I selected it was Connect and, when I tried that, the connection failed and the label now showed "Available via Orbi. Reset password and try again." Selecting the entry still gave only a Connect option, no password entry screen appeared, and the entry failed. This is now the only entry for my network in the list of available networks so I cannot connect my Android phone to wifi. I don't want to reset and reinstall the router all over again- can you tell me how to connect my phone to the wifi network?
Feb 07, 2023Guru - Experienced User
Also be aware of Random Mac feature on Android and Apple devices. When these are enabled, these cause a Uknown or a "DEV" host name to appear in the device list on the Orbi.
If your at home and not traveling, you don't need these enabled while at home.
Disable them so you can see the actual device host name appear on the Orbi system or Orbi app.
- mbailey555Feb 07, 2023AspirantThanks for the tip. I had actually checked that because random MAC seemed to be a reasonable possible cause of IP address issues. In my case, that option was already turned off.
- FURRYe38Feb 07, 2023Guru - Experienced User
đ
Ya not a fan of those featured being on by default unless you do lots of travel and connect to those freebee wifi sources. But at least we have a way to disable that while at home.
đ
