jeffer72
Jun 30, 2020Aspirant
Orbi RBK753S changes the Passkey after some config changes
I think I have found a serious bug in the firmware after setting up a new RBK75S system... I had the system fully configured, and then made a minor change to a setting - I don't recall which one ...
Jun 30, 2020Guru - Experienced User
So the wireless password had changed?
Can you try not using spaces in the wifi password? Just use simple characters and maybe a one or two special characters. #, ! &,$ would suffice. Not sure if spaces are a valid use in the wifi PW.
Please future post over in the Orbi AX forum as well for our model Orbi:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
- jeffer72Jul 01, 2020Aspirant
Sorry about posting in the wrong area - it was late and I was tired...
The password did change - when I viewed it after connecting with ethernet all the spaces were replaced with a sequence like #32; or maybe #&32; (I don't remember the actual sequence, but it definitely included semicolons and the 32 (ascii code for space). So something like "lazy dog" would change to lazy#&32;dog
My firmware version is V3.2.15.25_1.3.15 (updated automatically when I did initial setup).
I have been using a "complete sentence" passphrase (with spaces, punctuation, and proper capitalization) for a long time, and if I had to change this, it would be a painful process - I have many IoT devices on my network that need the network info hard coded - so I would have to completely reprogram all of those devices.
Thanks
- FURRYe38Jul 01, 2020Guru - Experienced User
Has a factory reset and setup from scratch on the RBR been performed? I would try this first and see if it happens again with the current PW configuration.
It's not really recommended to use spaces in PWs. Various mfrs may not fully support that kind of use in PWs thus can cause odd problems like this. Hopefully a reset may clear this up for you. If no, please try a PW with out spaces and see what happens. You may need to change from using passwords with spaces. I understand that it would be a pain to reconfigure devices. Once you do, then things would be better. I've never used spaced in any password. Seem to be too many variables that can cause the use of it to be problematic. You can contact NG support and see if they do support the space though.
I have given up...
I changed the password to remove spaces, and it was working ok for a while, but I went through some other issues (some Insignia branded Google smart speakers that I use all the time refused to pair no matter what I did). I even changed the SSID of the wifi to a new name and was still unable to connect them (i have 4 of them around the house). The last straw was the router going offline (no internet) even though the modem showed it was connected.
I did do a factory reset after the first instance of the spontaneous password change.It is now boxed up to go back to Costco. For $500 I expected better - I spent basically the entire day trying to make this stable and was unsuccessful. When it was connected, I did get fantastic speeds on some of my devices - especially those connected with ethernet cables to the satellite, but just seems to buggy at this point and not worth the frustation. I might have to stick with Asus at this point and see what they have to offer in mesh systems (my current router is an Asus RT-AX58U).
