JKH5199
Jun 22, 2020Aspirant
Orbi RBK753S issue with Desktop only
I have an odd issue. I upgraded to the Orbi RBK753S sold at Costco. Setup was easy and everything is working except for one item. I have a desktop with an Asus Wireless PCI-E Adapter. For some reason...
Jun 22, 2020Guru - Experienced User
Be sure that CTS and RTS values are changed to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
JKH5199
Thanks, I made the change, I’ve not seen any change as of yet.
Thanks
Thanks
- FURRYe38Jun 22, 2020Guru - Experienced User
What is the connection rate that the asus adapter is connecting at with the Orbi wifi?
- JKH5199Jun 22, 2020Aspirant
It says 650Mbps. However when it does connect I haven't gotten anywhere above 30Mbps on a speed test. I have 500 Mbps service.
What happens if you disable AX mode?
Ensure the adapter drivers are up to date.
Sounds like this adapter maybe having problems with Orbi wifi. If this is the only device thats having problems and others don't, I would look more into this adapter.
