RussRS
May 24, 2021Tutor
ORBI RBK753S
Hello, I have had the tri band router and 2 satellites for a month now. No issues the first three weeks, but this week, my internet connection started to drop once a day for about 5 minutes each day...
RussRS
May 24, 2021Tutor
Found it: Model: ONT1000G14
Thanks,
Russ
May 24, 2021Guru - Experienced User
Ok, thank you.
Also, "-First satellite is on the next floor up, right above the router, so 10 feet with a floor inbetween."
This RBS is too close the the RBR. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
- RussRSMay 24, 2021Tutor
I will move the satellite today and see if that helps.
Thanks,
Russ
