techymechy
Dec 12, 2023Aspirant
Orbi RBK760 with two satellites: What is the best NAS?
I have an Orbi RBK760 with two satellites that I bought from Costco. I want to set up a NAS for auto back up of a desk top PC that is connected to the Orbi router via CAT cable and Windows laptops ...
techymechy
I'm not exactly sure I want a Netgear NAS but I will post over there (I'm new here). I was wondering what people think of the Western Digital NAS in the above link.
Dec 12, 2023Guru - Experienced User
Something to post on there forum to see what there users think. Not much users here regarding WD NAS.
NG has a NAS forum however not sure if there doing anything current production. Not sure if there even in the NAS production anymore. https://community.netgear.com/t5/ReadyNAS-Network-Storage/ct-p/readynas
Personally, I have two D-Link DNS-345s from years ago. Solid and stable and couldn't be happier. Just upgraded one of the to all 4Tb drives. They do what I want.
Good Luck.
- techymechyDec 12, 2023Aspirant
Thanks for the reply.
Can you do wireless downloads to your DLink NAS by the ORBI's? I read somewhere that the ORBI does not allow the NAS to be detected on the wireless network. The wired network (desk top Windows PC) can see the NAS, but the Windows and MAC laptops could not be detected. I believe that this is when the NAS is connected to a satellite ORBI but I'm not sure if it is also true when the NAS is on the base ORBI.
Do you know?
- FURRYe38Dec 13, 2023Guru - Experienced User
Ya I seen posts with users having NAS connected to the RBS.
I don't. Mines all connected behind the RBR and with Switches so I don't any problems from other connected devices. It's recommended to have NAS connected behind a router or with a switch behind the router. Best performances and connectivity and avoid problems.
- techymechyDec 14, 2023Aspirant
So, you recommend that I purchase a separate switch to plug into the ORBI base station switch and then connect that into my NAS?
I only want one NAS for data back up. I thought it would be best to connect that to the Orbi base switch.
I'm thinking I'll just bite the bullet and buy a 2 drive NAS and put some descent sized drives in it and then have them mirrored (RAID 1).
Do you know if I get a less expensive NAS - say: Asustor Drivestor 2 AS1102T
Will this allow me to do the following with the ORBI:
1. My desktop is connected to my ORBI base switch via CAT cable. My internet modem is also connected to my Orbi Switch.
2. I will have both Windows and Mac Laptops which use the ORBI wireless around the house.
3. I would like to get a NAS that will be connected to the ORBI switch via CAT cable. This NAS will allow daily updates from the CAT wired desktop and the laptops.
What drives do you recommend for a new NAS?
As far as data integrity, we will have a internet storage for critical storage (taxes, pictures, etc.). I am hoping that I can have this NAS to rebuild a new drive if the main boot drive dies on any of my PC's/laptops.
