globespy
May 26, 2022Apprentice
Orbi RBK763S - Costco - Replacing RBK53
After the most recent FW was pushed to my devices (without me having any say in the matter), my entire RBK53 system is dysfunctional, replacing multiple devices IP addresses with IP starting '172.' ...
May 26, 2022Guru - Experienced User
I suppose you can set up a 172 IP address subnet. I would recommend trying the default 192.168.1.# first.
I personally use 192.168.0.100 to .150 since I only have limited amount of devices. I don't seen the entire .254 range
globespy
I never use ISP devices since they are 'all-in-one' router/modems.
I purchased Motorola MB8611
Not sure about what you mean by setting up subnet? I can't do/change anything on the modem, it's just a 'dumb' device that passes through the signal?
