globespy
May 26, 2022Apprentice
Orbi RBK763S - Costco - Replacing RBK53
After the most recent FW was pushed to my devices (without me having any say in the matter), my entire RBK53 system is dysfunctional, replacing multiple devices IP addresses with IP starting '172.' ...
globespy
I never use ISP devices since they are 'all-in-one' router/modems.
I purchased Motorola MB8611
Not sure about what you mean by setting up subnet? I can't do/change anything on the modem, it's just a 'dumb' device that passes through the signal?
May 26, 2022Guru - Experienced User
Ok. Just checking.
Try the default IP address string first...
- globespyMay 26, 2022Apprentice
What do you mean by this?
Sorry if I'm not understanding
- FURRYe38May 26, 2022Guru - Experienced User
Just try the default out of the box IP address range.
You can setup IP address reservations for the RBS and your devices.
How many devices do you have in total?
When you say try 'out of the box', isn't that what I would already be doing since I haven't touched any of the subnet stuff?
I have less than 25 devices including the 2 satellites, one of which won't work because it is using a '172.' IP address:
