MarkSL
Apr 29, 2020Aspirant
Orbi RBK842 - Can I add Orbi to my AT&T network?
I have AT&T fiber. AT&T provides a combo modem and router box for wired (4 ports) and wireless (Wi-Fi). The network is already set up. Let's call the wireless network "MyATTHome". What I want to...
Apr 29, 2020Guru - Experienced User
Please post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Good Luck.
