HelpMeBrah
Aug 14, 2022Aspirant
Orbi RBK850 & synology NAS - Cant connect to WebDav server from outside the home network
I recently upgraded my wifi to the Orbi RBK850 system. I previously had an apple Airport Extreme. I have a Synology NAS connected via Cat6 directly to the Router. Since changing routers, I can n...
Aug 15, 2022Guru - Experienced User
have you checked with synology to see if they require a specific setting or change with your network?
What modem/gateway is the router connected to?
- HelpMeBrahAug 21, 2022Aspirant
Synology basically just advises me to make sure I have port forwarding set up correctly, which is kind of a vague generic response it seems....
The cable modem I have is a ARRIS SURFboard SB8200 DOCSIS 3.1 Cable Modem.
