schadan's avatar
schadan
Guide
Mar 30, 2023
Orbi RBK850 in AP mode can't connect to satellite
Hi, seems that my problem is not new but I was not able to find a working solution: I'm running a Orbi RBK850 together with two RBS850 in my home network. I've done first the setup of the whole syste...
  • schadan's avatar
    schadan
    Apr 01, 2023
    Hi,
    the problem is solved πŸ™‚
    A simple cause had a big effect - I could see in the pfsense fw logs that outbound icmp was blocked - seems that the RBK is pinging to some cloud front systems regularly to see whether it has an internet connection. After enabling it it worked like a charm, the gui shows internet connection & I was able to sync both satellites.
    Now I only have one small (not really urgent) problem left & that is that I'm getting (only on the RBK) a http 500 when connecting to the WebGUI via DNS name in the URL - using the ip address instead is working. But for this I will open another thread.
    Thank You very much for Your help, really appreciated πŸ™‚
