LucGov
Sep 21, 2021Star
ORBI RBK850 keeps disconnecting with ISP after firmware update V4.6.3.16
ORBI RBK853 WIFI keeps disconnecting with ISP after firmware update V4.6.3.16
LucGov
Sep 28, 2021Star
Yes, I did a power up several times of my ORBI 853. Also power down/up of the provider modem/bridge.
II even did a roll-back of the software to version V4.6.3.9, but that doens't make a change.
The system worked perfect before this FW upgrade.
Any news from the Netgear helpdesk about a fix ?
Sep 28, 2021Guru - Experienced User
What happens if you leave the RBR and RBS turned OFF over night then back on first thing in the morning?
Were seeing others post that leaving the Orbi units unplugged for several hours is helping to correct problems seen.
No time frame on when fw new is forth coming. NG doesn't post this.
