PeterHK
Sep 09, 2020Guide
Orbi RBK850 Speedtest Not Working
I have RBK850 with three RBS850 satellites and after one day the Speedtest on the Orbi App and on the QoS setup on the Orbi Web interface have not worked. When I try to run the speedtest I keep reci...
JanSt
Nov 01, 2020Aspirant
Yes, I have the same issue.
Nov 01, 2020Guru - Experienced User
Are you speed testing wireless or wired?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
JanSt wrote:Yes, I have the same issue.
