PeterHK
Sep 09, 2020Guide
Orbi RBK850 Speedtest Not Working
I have RBK850 with three RBS850 satellites and after one day the Speedtest on the Orbi App and on the QoS setup on the Orbi Web interface have not worked. When I try to run the speedtest I keep reci...
C4H7
Jan 26, 2021Star
Same problem here. Wish I never would have bought this buggy $1000+ Albatross.
Jan 26, 2021Guru - Experienced User
C4H7 wrote:Same problem here. Wish I never would have bought this buggy $1000+ Albatross.
- C4H7Jan 26, 2021Star
Firmware: V3.2.16.22
Motorola MB8600
- KMDonlonJan 26, 2021VirtuosoThe lastest firmware should help you out:
New RBR850 / RBS850 Series Firmware Version v3.2.17.12 Released
New Features and Enhancements:
Supports the new device notification feature
Includes some security enhancements
Security Fixes:
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
Bug Fixes:
Fixes issues with Speedtest in the Orbi app
Fixes device access issues with the web UI
Fixes some web UI related issues
Download Link:
https://www.netgear.com/support/product/rbk852.aspx#download - FURRYe38Jan 26, 2021Guru - Experienced User
Try the newer FW as suggested. I have it loaded and it's working.
C4H7 wrote:Firmware: V3.2.16.22
Motorola MB8600
