PeterHK
Sep 09, 2020Guide
Orbi RBK850 Speedtest Not Working
I have RBK850 with three RBS850 satellites and after one day the Speedtest on the Orbi App and on the QoS setup on the Orbi Web interface have not worked. When I try to run the speedtest I keep reci...
Jan 26, 2021Guru - Experienced User
C4H7 wrote:Same problem here. Wish I never would have bought this buggy $1000+ Albatross.
C4H7
Jan 26, 2021Star
Firmware: V3.2.16.22
Motorola MB8600
- KMDonlonJan 26, 2021VirtuosoThe lastest firmware should help you out:
New RBR850 / RBS850 Series Firmware Version v3.2.17.12 Released
New Features and Enhancements:
Supports the new device notification feature
Includes some security enhancements
Security Fixes:
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
Bug Fixes:
Fixes issues with Speedtest in the Orbi app
Fixes device access issues with the web UI
Fixes some web UI related issues
Download Link:
https://www.netgear.com/support/product/rbk852.aspx#download - FURRYe38Jan 26, 2021Guru - Experienced User
Try the newer FW as suggested. I have it loaded and it's working.
C4H7 wrote:Firmware: V3.2.16.22
Motorola MB8600
- Fritzsche0529Jan 26, 2021Apprentice
My SpeedTest has been working for months since my last factory reset. I had to reboot my router yesterday, and the SpeedTest stopped working again. I don't want to do the factory reset if I can avoid it. I see that there is a FW update available, but it does not appear to be available for my system, or maybe just not in my area. Any intel on the FW update? I have 3.2.16.22...and am not given an update option to 3.2.17....
