Joe1981
Aug 10, 2022Aspirant
Orbi RBK852 - Connection Problem - Violet/Orange glow
Hi i also posted in the german forum, but maybe i get my help here faster. Since around 6-9 months i have problems with my Satellite. I also tried placing the router in the same room with the...
Aug 10, 2022Guru - Experienced User
Be sure the RBR and ALL RBS are using same version of FW.
Try removing the disconnected RBS from the RBR if seen on the RBS web page. Then factory reset the RBS by pressing the reset button for 15 seconds then release. Then when the front LED is pulsating WHITE, press the sync button on the RBS then on the RBR. See if this will get the RBS to fully sync.
If this doesn't work, try connecting the RBS to the back of the RBR using a ethernet cable and see if you can access the RBS web page in a browser.
