pb01890
Oct 28, 2020Star
Orbi RBK852 - Selection of 5GHz channel 36
New owner of RBK852. According to the app WiFi Explorer the 5GHz channel in use by Orbi is 40, despite being set to 36. I changed it to 48 and it is correctly displayed in WiFi explorer. Set it back ...
Oct 28, 2020Guru - Experienced User
What browser are you using? Try a different browser?
Be sure to clear out all browser caches before entering the RBRs web page.
pb01890
Oct 28, 2020Star
Thanks. Latest firmware. With my old RBK40 Channel 36 was correctly set and reported by WiFi Explorer.
Can you maybe download WiFi explorer Lite and let me know your findings?
