pb01890
Oct 28, 2020Star
Orbi RBK852 - Selection of 5GHz channel 36
New owner of RBK852. According to the app WiFi Explorer the 5GHz channel in use by Orbi is 40, despite being set to 36. I changed it to 48 and it is correctly displayed in WiFi explorer. Set it back ...
Partizan161
Nov 03, 2020Aspirant
First try with the previous firmware version and check if the problem still occurs ,
As it is likely to be a firmware issue, try to return to the previous Firmware , and or upgrade back to newest one .
Also check the realease notes.
- pb01890Nov 03, 2020Star
FURRYe38 is on a previous firmware, same findings....
- FURRYe38Nov 03, 2020Guru - Experienced User
Yes it was on v11.2 for me as well...
Thanks.. It seems this issue will never be escalated. They keep on coming back to me with more questions: did you try different analysers, did you try with another laptop, what are the specs of the laptop,.... it seems they do not even look at this thread!
I will simply stop responding, it is hopeless... what a uselss support
