pb01890
Oct 28, 2020Star
Orbi RBK852 - Selection of 5GHz channel 36
New owner of RBK852. According to the app WiFi Explorer the 5GHz channel in use by Orbi is 40, despite being set to 36. I changed it to 48 and it is correctly displayed in WiFi explorer. Set it back ...
pb01890
Nov 03, 2020Star
FURRYe38 is on a previous firmware, same findings....
Nov 03, 2020Guru - Experienced User
Yes it was on v11.2 for me as well...
- pb01890Nov 03, 2020Star
Thanks.. It seems this issue will never be escalated. They keep on coming back to me with more questions: did you try different analysers, did you try with another laptop, what are the specs of the laptop,.... it seems they do not even look at this thread!
I will simply stop responding, it is hopeless... what a uselss support
- FURRYe38Nov 03, 2020Guru - Experienced User
Please do NOT stop responding to NG support questions. If theres responding to you, it means there looking into it and need more information is all. Lets give it to them. You can repeat to them to reivew this forum thread as well as we have others that see the same issue as well as I do. They can contact me as well if needed. I'm in there database. :smileywink:
The more we give feedback the more there apt to look more into this and check it out.
And I have checked several different WiFi apps, including NGs WiFi analytics app for Android Pad, for this and they all report channel 40 when 36 is selected in the UI. :smileywink:
