pb01890
Oct 28, 2020Star
Orbi RBK852 - Selection of 5GHz channel 36
New owner of RBK852. According to the app WiFi Explorer the 5GHz channel in use by Orbi is 40, despite being set to 36. I changed it to 48 and it is correctly displayed in WiFi explorer. Set it back ...
KMDonlon
Nov 04, 2020Virtuoso
I just tried channel 36 & can 100% confirm the "bug"
Shows channel 40 in the web GUI along with my WiFi analyzer app but channel 36 is selected in the radio button drop down in WiFi setup.
- FURRYe38Nov 04, 2020Guru - Experienced User
Thanks for confirming this. Hopfully NG can review this. :smileyembarrassed:
- FURRYe38Nov 22, 2020Guru - Experienced User
NG doesn't make it known when fixes are forth coming. User have to be patient. Any one seeing this problem is recommended to contact NG support to let them know.
Thank you.
- pb01890Nov 24, 2020Star
Case has been escalated to L2 Netgear support. Have just been asked to send a debug_log file after changing from channel 36 to 40 and back to 36. File will be sent to their engineers.
