AwkAndy
Nov 14, 2021Aspirant
Orbi RBK852 - Unable to connect Big Ass Fans - Haiku series
I've just switched from an Orbi RBR50 to an Orbi RBK852 to extend the reach of our mesh network. I had no problems connecting our Big Ass Haiku fans to the Orbi RBR50 but I'm unable to conne...
- Nov 15, 2021
Try CTS avalues to 2347 under Advanced Tab/Advanced Settings/Wireless Settings and see.
AwkAndy
Nov 15, 2021Aspirant
That did the trick. Thanks!
Nov 15, 2021Guru - Experienced User
Orbi AX SSID by default is always broadcast and can not be hidden.
So did you get these devices working?
- AwkAndyNov 15, 2021Aspirant
I did. Thanks for your help!
- FURRYe38Nov 16, 2021Guru - Experienced User
So what did you do to get them working?
- AwkAndyNov 16, 2021Aspirant
My apologies for not being clearer. After some experimentation, I've discovered that I can get the fans to connect if I disable AX mode on 2.4Ghz AND set the CTS value for 2.4Ghz to 2347. Either one by itself won't work. And it's a real pain because if you change either of those settings after you've managed to reconnect the fans, you have to go through the whole process again in order to connect the fans again. So once you've changed those settings, don't change them again!
