PhilRoberts
Sep 13, 2021Aspirant
orbi RBK852 - update firmware to include "Smart Parent controls"
Hi I've just purchased a new orbi RBK852. I've noticed there is a new release of firmware online. My orbi has completed the firmware update and is running V3.2.18.1_1.4.14 The latest firmware vers...
Sep 13, 2021Guru - Experienced User
I recommend avoiding updating FW to v4 as we are seeing some issues with v4 FW:
You can update if you wish to however know this that you can't seemlessly revert back to v3 FWs after updating to v4 with out incurring a hassle of processes. It can be done though. NG doesn't officially support downgrading back to v3 after v4 has been applied.
- R800bbySep 13, 2021Tutor
Hi FURRYe38 pleasae tell me how I can defer back to my previous fireware.
I update the firmware to V4.6.3.6 and having all sorts of issues with both Wifi and ethernet connections on radom devices.
My phone does not connect but the Orbi app shows it's connected.
Pease help me get back to my previous fireware.
I have downloaded the previous one and tried to manual do it, but when it asks for me to confirm, there is no YES option only NO.
HEEEEEEEELP
- FURRYe38Sep 14, 2021Guru - Experienced User
What model Orbi do you have?
HEEEEEEEELP
