Ryan4332
Dec 18, 2021Aspirant
Orbi RBK852 4.6.3.16 broken (Solved)
This topic is only for the Netgear Orbi RBK852 / RBK853 / RBK854 / RBR850 Introduction: I bought my Netgear Orbi RBK852 last year. It's work fine and I am happy with that until they release 4.6...
- Dec 18, 2021Especially with Netgear, always do a "Pin Hole Reset" after a "New Version Update" and input the operational information by hand. NEVER use a Backup File. Especially across different versions.
ChrisBoer
Dec 27, 2021Guide
ASUS 2,4Ghz/5Ghz PCI card, I have updated the drivers no issues since.
So no more wifi drops also I have not reset my RB850 either.
So updated both the sattelites and the router.
Dec 27, 2021Guru - Experienced User
Going on 9 days here:
Basic Information
Firmware Version: V4.6.5.14_2.0.54T4
seal: v2.0.25-0
CPU Load: 9.71%
Memory Usage(Used/Total): 331 MB/874 MB
System Uptime: 8 days 23:55:25
