Ryan4332
Dec 18, 2021Aspirant
Orbi RBK852 4.6.3.16 broken (Solved)
This topic is only for the Netgear Orbi RBK852 / RBK853 / RBK854 / RBR850 Introduction: I bought my Netgear Orbi RBK852 last year. It's work fine and I am happy with that until they release 4.6...
- Dec 19, 2021Especially with Netgear, always do a "Pin Hole Reset" after a "New Version Update" and input the operational information by hand. NEVER use a Backup File. Especially across different versions.
Dec 27, 2021Guru - Experienced User
I presume you got this from NG support?
How long has the system been running with it loaded?
NGSvensk wrote:
I updated to V4.6.6.11 and did not do a factory reset and so far so good!
ChrisBoer
Dec 27, 2021Guide
Yes he got it from me and I got it from NetGear Customer support.
- NGSvenskDec 28, 2021Apprentice
Update - Lost internet access on 5G on the RBS. Took quite a while but after some tweaking and rebooting it is back.
- FURRYe38Dec 28, 2021Guru - Experienced User
Did you factory reset and setup from scratch on both RBR and RBS after loading the FW?
Something I did with my RBR after getting v4.6.5.14 from ChrisBoer
Mines been online for 10 days now:
Basic Information
Firmware Version: V4.6.5.14_2.0.54T4seal: v2.0.25-0
CPU Load: 9.74%
Memory Usage(Used/Total): 331 MB/874 MB
System Uptime: 10 days 02:51:01
I did not do a factory reset but will likely do it on the weekend.
- duomonoJan 01, 2022Star
Hi there
I'm still on v4.6.3.16_2.0.51
Should I upgrade now?- FURRYe38Jan 01, 2022Guru - Experienced User
Try this version listed in this thread, MIne was online for a full 12 days with out issues or try this newer version:
duomono wrote:
Hi there
Should I upgrade now?- duomonoJan 19, 2022StarThank you. Mine has been working well with no issues since we updated for over a week now.
