Ryan4332
Dec 18, 2021Aspirant
Orbi RBK852 4.6.3.16 broken (Solved)
This topic is only for the Netgear Orbi RBK852 / RBK853 / RBK854 / RBR850 Introduction: I bought my Netgear Orbi RBK852 last year. It's work fine and I am happy with that until they release 4.6...
- Dec 18, 2021Especially with Netgear, always do a "Pin Hole Reset" after a "New Version Update" and input the operational information by hand. NEVER use a Backup File. Especially across different versions.
frde
Dec 29, 2021Aspirant
During past months I try everything I can find on internet to solve the problem but without success.. unfortunately this is another attempt to add to the failed ones because following these steps and using firmware V4.6.5.14_2.0.54T4 the problem remains the same.
WiFi network comes and goes and the satellite go Out of sync and it comes back okay about every 30 seconds.
This appens only with AP mode.
Any suggestions? Other firmware to try?
I can solve this problem only with a downgrade to V3.2.18.1_1.4.14 but this can't be a solution, this is only a temporary workaround to not remain without wifi :(
(RBR850 + RBS850)
Dec 30, 2021Guru - Experienced User
I loaded this up today and will monitor it:
- ahswpDec 30, 2021Apprentice
IS THERE A VERSION FOR 750?
