Ryan4332's avatar
Ryan4332
Orbi RBK852 4.6.3.16 broken (Solved)
This topic is only for the Netgear Orbi RBK852 / RBK853 / RBK854 / RBR850 Introduction: I bought my Netgear Orbi RBK852 last year. It's work fine and I am happy with that until they release 4.6...
  • FarmerBob1's avatar
    FarmerBob1
    Dec 18, 2021
    Especially with Netgear, always do a "Pin Hole Reset" after a "New Version Update" and input the operational information by hand. NEVER use a Backup File. Especially across different versions.
