Ryan4332
Dec 18, 2021Aspirant
Orbi RBK852 4.6.3.16 broken (Solved)
This topic is only for the Netgear Orbi RBK852 / RBK853 / RBK854 / RBR850 Introduction: I bought my Netgear Orbi RBK852 last year. It's work fine and I am happy with that until they release 4.6...
- Dec 18, 2021Especially with Netgear, always do a "Pin Hole Reset" after a "New Version Update" and input the operational information by hand. NEVER use a Backup File. Especially across different versions.
NGSvensk
Dec 31, 2021Apprentice
One problem came up-- we have a ATA that I had set up through the Orbi. =>Modem -Orbi-ATA.
Since the latest firmsware we had internet connection to the ATA but it could not register. Put the ATA IP address on DMZ as a test and still it could not register. Opened IP Phone port- still it could not register.
Now I am going Modem -ATA - Orbi and all is good.
Not sure why ATA could not register through this latest firmware.
Jan 01, 2022Guru - Experienced User
- NGSvenskJan 02, 2022Apprentice
I have a Hitron 32x8, however I finally had he time to do a factory reset and set up the router and the satelite. Kind of weird but the ATA works again plugged in direct to the router Modem -Orbi-ATA.
I know it has been said before,,, factory reset does correct some issues..moving forward I will do a factory reset after firmware updates
- FURRYe38Jan 02, 2022Guru - Experienced User
