Ryan4332
Dec 18, 2021Aspirant
Orbi RBK852 4.6.3.16 broken (Solved)
This topic is only for the Netgear Orbi RBK852 / RBK853 / RBK854 / RBR850 Introduction: I bought my Netgear Orbi RBK852 last year. It's work fine and I am happy with that until they release 4.6...
- Dec 18, 2021Especially with Netgear, always do a "Pin Hole Reset" after a "New Version Update" and input the operational information by hand. NEVER use a Backup File. Especially across different versions.
Jan 01, 2022Guru - Experienced User
Try this version listed in this thread, MIne was online for a full 12 days with out issues or try this newer version:
duomono wrote:
Hi there
I'm still on v4.6.3.16_2.0.51
Should I upgrade now?
duomono
Jan 19, 2022Star
Thank you. Mine has been working well with no issues since we updated for over a week now.
