Ryan4332
Dec 18, 2021Aspirant
Orbi RBK852 4.6.3.16 broken (Solved)
This topic is only for the Netgear Orbi RBK852 / RBK853 / RBK854 / RBR850 Introduction: I bought my Netgear Orbi RBK852 last year. It's work fine and I am happy with that until they release 4.6...
- Dec 18, 2021Especially with Netgear, always do a "Pin Hole Reset" after a "New Version Update" and input the operational information by hand. NEVER use a Backup File. Especially across different versions.
Feb 16, 2022Guru - Experienced User
Ya, NG knows about that too. You going to keep the MK system?
Eriksen76 wrote:
Thanx for your assistance, will try that when I recieve the router. Hopefully this product is way better than the MR60/MS60 which got my hair turning grey.
Eriksen76
Feb 16, 2022Apprentice
Maby I will try to sell it. I don't think coverage of it is working all too well.
I have had it for about 1,5 years.
Furthermore when my kid plays on his room it very often lags with Nighthawk - Even though I have cabled his PS4 Pro directly to a MS
So hopefully this RBK853 will improve overall speed. At least thats what i expect.
At the price level of RBK853 it has to be very good and stable. We have a house of 141 square meters, so 853 should do.
What can i expect?
- FURRYe38Feb 16, 2022Guru - Experienced User
30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡Look me up about the MK system.
- Eriksen76Feb 16, 2022Apprentice
FURRYe38 wrote:30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.
Thanks, any comments about what to expect when comparing with old system?
