timroswell1's avatar
timroswell1
Orbi RBK852 and Leviton WiFi products.
I upgraded to an Orbi RBK852 router and satellitte. I have 32 Levition WIFi devices connected to my network. Some are connected at 2.4G & others on 5G. What I'm seeing is random Levition showing off line in their app & need to be reconnected. But I noticed last night 4 were off-line but 24 hours later back on line. It seems to be a random issue. Leviton tells me i need to connect them at 2.4G.
Evidently Orbi is steering some to 5G & thats the issue???
Any suggestions?
  • FURRYe38's avatar
    Devices maybe picking the frequency as it's up to devices to picck and chose where they connect to.
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Try setting CTS values to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
    May help with the transitions between frequencies...
    • timroswell1's avatar
      timroswell1
      Sq ft 4400.
      ORBI router is in basement where all netwrok equipment is.
      Satellite is on 2nd floor over looking greatroom, 10 Liviton devices with 30-35 feet of it. Standard drywall construction
      Currently
      Enable AX - Settings
      2.4g  is unchecked, Tech Support told me to change that so Trane thremostat would connect
      5g is checked
      2.4g channel is auto.
      5g channel is 48.
      CTS is set to 64. But I've seen recommended values at 500 or 2347 (which one post said was not recommended, use 500 instead.
      • FURRYe38's avatar
        So if you re-enable AX on 2.4Ghz with a checking the check box, does the one device remain connected?
        timroswell1 wrote:
        Sq ft 4400.
        Currently
        5g is checked
        5g channel is 48.
