marero
Jul 22, 2022Aspirant
Orbi RBK852 and satellites- service keeps dropping
Hello- I have an Orbi RBK852 with three wired satellites (we just moved into an old house with insanely thick stone walls that was blocking the signal when we tried to use them as wireless, and I nee...
Jul 22, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
How are the RBS connected to the RBR via ethernet? Directly to the back of the RBR or is there a LAN switch in between them?
What CAT# lan cable are you using? CAT6 is recommended.
