marero
Jul 22, 2022Aspirant
Orbi RBK852 and satellites- service keeps dropping
Hello- I have an Orbi RBK852 with three wired satellites (we just moved into an old house with insanely thick stone walls that was blocking the signal when we tried to use them as wireless, and I nee...
Jul 22, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
How are the RBS connected to the RBR via ethernet? Directly to the back of the RBR or is there a LAN switch in between them?
What CAT# lan cable are you using? CAT6 is recommended.
marero
Jul 23, 2022Aspirant
Current firmware version is V4.6.8.2.
I just have the Orbi router connected directly to the FIOS cable. When I called Verizon they said not to connect two routers because it would confuse the service (?)
The house is 3000 sq feet but with very thick stone walls which is why I connected the RBR with the 3 RBS (directly, no LAN switc h.
Using CAT6 cables for every connection.
- FURRYe38Jul 23, 2022Guru - Experienced User
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
