DatabaseJase
Mar 03, 2021Luminary
Orbi RBK852 Check Satellite Signal Strength
Just upgraded from an RBK52 (plus a 3rd RBS50) to the RBK852 and I wanted to check the signal strength between the Satellite and the Router like you could on the RBR50: http://192.168.1.1/online_...
Mar 04, 2021Guru - Experienced User
it only shows connection rates but you can hit the show stats button the Advanced tab/Internet port page to see what the rates are. If rates seem low then this would be one inidiation there maybe a problem. Distance or otherwise.
- DatabaseJaseMar 05, 2021Luminary
That's a shame as it was useful information on the RBR50. Also tried a Linksys Velop AX5300 [1] and that also shows the signal strength (along with lots of useful information). Shame this isn't available on the RBR850 as it can help when you're trying to move the satellite as far away as possible while keeping signal strength below -67dBm so as to not impact backhaul speed.
[1] In the end I returned the Velop AX5300 as only one 5Ghz band is WiFi6 and the other is WiFi5 only (Velop also dynamically chooses which 5Ghz network to use for backhaul which means that sometimes the WiFi6 network is taken up by backhaul and unavailable to clients).
