pss16
Jul 19, 2020Aspirant
Orbi RBK852 compatibility with Google wifi
Hi All, I upgraded from google wifi to the orbi RBK852 router. I have the 3 google wifi routers at home. Is there a way i can connect them to this Orbi router as extensions? This way I can utiliz...
Jul 19, 2020Guru - Experienced User
Something to try and see. No idea if they will work or not.
If there not AX or tri band supporting, may not work. Try disabling AX mode on the RBR.
Let us know.
pss16
Many thanks for the response. How do I disable the AX mode to try? do i have to use the orbi app to look for the google wifi?
- FURRYe38Jul 19, 2020Guru - Experienced User
Use a PC or Laptop and connect to the RBRs web page. It's on the wireless settings page.
You'll need to use googles app to get them connected.
- pss16Jul 19, 2020Aspirant
I connected physically hard wired the google wifi to the Oribi satellite and it had the same network name and it actually worked. So now its like a router connected to a router. Any thoughts on how to make it connect via wifi so that these google points just become satellites of the orginal Orbi. Many thanks in advance
- FURRYe38Jul 20, 2020Guru - Experienced User
Try the google app to see if it will help you get those connected. Something to ask Google about.
