pss16
Jul 19, 2020Aspirant
Orbi RBK852 compatibility with Google wifi
Hi All, I upgraded from google wifi to the orbi RBK852 router. I have the 3 google wifi routers at home. Is there a way i can connect them to this Orbi router as extensions? This way I can utiliz...
pss16
Many thanks for the response. How do I disable the AX mode to try? do i have to use the orbi app to look for the google wifi?
Jul 19, 2020Guru - Experienced User
Use a PC or Laptop and connect to the RBRs web page. It's on the wireless settings page.
You'll need to use googles app to get them connected.
- pss16Jul 19, 2020Aspirant
I connected physically hard wired the google wifi to the Oribi satellite and it had the same network name and it actually worked. So now its like a router connected to a router. Any thoughts on how to make it connect via wifi so that these google points just become satellites of the orginal Orbi. Many thanks in advance
- FURRYe38Jul 20, 2020Guru - Experienced User
Try the google app to see if it will help you get those connected. Something to ask Google about.
- pss16Jul 20, 2020Aspirant
I checked with google and they are saying that I should not connect the google wifi to netgear. They want the google wifi to be only connected to the modem. I asked them can I turn off dhcp and connect the google wifi with netgear so that only netgear will assign the dynamic ips. They told that it should not be done. I still do not know of a way to connect via wifi.
