skrishnan37
May 21, 2020Aspirant
Orbi RBK852-Connect to satellites by Ethernet?
Recently got the RBK852 with 2 satellites. Are any of the ports on the satellites WAN & able to connect to the main unit or is it all remotely? (My house has ethernet ports throughout so I'm not wo...
May 21, 2020Guru - Experienced User
Working with most recent FW as of yesterday:
- skrishnan37May 22, 2020AspirantWith those speeds, should I be using cat 6 cables only?
And are Ethernet cables like cell phone charging cables. The longer the cable, the less the performance?- FURRYe38May 22, 2020Guru - Experienced User
At minimum, yes. Cat6 or higher. I've been using CAT6 for years. Great performances.
No they are not.
