skrishnan37
May 21, 2020Aspirant
Orbi RBK852-Connect to satellites by Ethernet?
Recently got the RBK852 with 2 satellites. Are any of the ports on the satellites WAN & able to connect to the main unit or is it all remotely? (My house has ethernet ports throughout so I'm not wo...
jcrim
May 22, 2020Tutor
I just received a new RBK752 pair last week, and I use Ethernet backhaul between the router and the Satellite. I'm actually using cat5e - cat6 would be preferable, but it's what I had when I installed the cable for my TV a few years ago. I'm getting > 300Mbps over it, even though I believe it's rated lower.
IMO an ethernet backhaul is always preferable to a wireless backhaul, if you can use it. Fortunately the RBK752 and RBK852 support it. It was automatically detected upon setup, so very easy to configure.
May 23, 2020Guru - Experienced User
Enjoy it. :smileywink:
- nakenergyJun 08, 2020Guide
What does it do to the backhaul wireless radios if ethernet backhaul is turned on? Are those radios freed up to handle more traffic?
- FURRYe38Jun 08, 2020Guru - Experienced User
No, the backhaul radios are idle waiting for a connection should the ethernet connection be disabled or something happens to the ethernet connection. The backhaul isn't user configurable.
nakenergy wrote:What does it do to the backhaul wireless radios if ethernet backhaul is turned on? Are those radios freed up to handle more traffic?
