skrishnan37
May 21, 2020Aspirant
Orbi RBK852-Connect to satellites by Ethernet?
Recently got the RBK852 with 2 satellites. Are any of the ports on the satellites WAN & able to connect to the main unit or is it all remotely? (My house has ethernet ports throughout so I'm not wo...
May 23, 2020Guru - Experienced User
Enjoy it. :smileywink:
nakenergy
Jun 08, 2020Guide
What does it do to the backhaul wireless radios if ethernet backhaul is turned on? Are those radios freed up to handle more traffic?
- FURRYe38Jun 08, 2020Guru - Experienced User
No, the backhaul radios are idle waiting for a connection should the ethernet connection be disabled or something happens to the ethernet connection. The backhaul isn't user configurable.
nakenergy wrote:What does it do to the backhaul wireless radios if ethernet backhaul is turned on? Are those radios freed up to handle more traffic?
