arinehim
Oct 24, 2021Aspirant
Orbi RBk852 Connecting to device with no internet
Today I set up my Orbi RBR850 system. Getting the system up and working was more difficult than I anticipated but it is now up. I've been able to connect all of my devices except my Desktop computer....
- Oct 24, 2021
Found Solution!
I managed to get the system working. What I did was first perform a factory reset on all of the satelites. Then I performed a new setup using only the main router. I also made sure not to have any of the existing devices plugged into the router while it was performing the new setup. Once it was up I slowly added more devices to the newtwork. and I added satelite recieves one at a time.
I'm going to continue to monitor it as time goes by but for now things seem to be ok.
Oct 24, 2021Guru - Experienced User
What wireless card is in the desktop and what driver is installed for it?
What modem/gateway is the orbi connected to?
- arinehimOct 24, 2021Aspirant
The modem I have the Orbi connected to is the Arris Surfboard SB6183.
The Wireless card I have is Intel Wireless AC 9560 160 MHz. The driver is a from Microsoft, its whatever driver was installed when I installed the motherboard. The version is 21.10.2.2. The motherboard is the Asus STRIX Z390-E Gaming ATX LGA1151.
Found Solution!
- FURRYe38Oct 25, 2021Guru - Experienced User
I do same thing. I also add RBS first, then setup IP address reservatins for the RBS as well.
