Whoskyle
May 15, 2022Tutor
Orbi RBK852 Disconnecting Everyday
Hey All, Recently every early morning around 0600 the Orbi loses internet connection. I am running Century Link Fiber 1GBPS running from a ONT to the Orbi. Rebooting the Orbi works and then the ...
May 15, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Whoskyle
May 15, 2022Tutor
It’s a Calix Gigapoint 803G
My Orbi is running 4.6.8.2
I have done all the other steps as well
- FURRYe38May 15, 2022Guru - Experienced User
Does the front LED on the RBR turn PINK when this happens?
What is the CAT# lan cable between the ONT and RBR? CAT6 is recommended...
