Bandito
Oct 26, 2019Luminary
Orbi RBK852 Experience
Just wanted to share my experience so far with the new RBK852. I have two devices that have WiFi-6, so thought I'd take the plunge and see how things went. I went through the app installation pr...
Bandito
Nov 05, 2019Luminary
Well, WiFi Sweet Spot issues aside, the new Orbi RBK852 system is performing well for me so far. By saying that, hopefully I haven't jinxed anything.
My old Orbi RBK53 system had an issue where after 2-3 days throughput on WiFi would drop to one-tenth of normal, requiring a reboot to restore full speed. After many months, a firmware update finally fixed the issue, but a with the just-released firmware update it seems to have gone back to its old slow ways again.
The new system has been stable for me since Saturday, so I'll start checking for slowdowns now, but hopefully won't experience this same problem again.
Nov 05, 2019Guru - Experienced User
Good to hear. Ya I think the 852 system is pretty solid in wifi operation and coverage.
Was curious, what FW fixed your RBK53 slow down and did you do a factory reset and setup from scratch after you applied that lastest FW update on the RBK53?
Seems odd that for you, a 50 series seems problematic. Seems like a enviroment issue as well.
Bandito wrote:Well, WiFi Sweet Spot issues aside, the new Orbi RBK852 system is performing well for me so far. By saying that, hopefully I haven't jinxed anything.
- BanditoNov 05, 2019Luminary
FURRYe38 ,
The current firmware available on the support site for the RBK53, 2.5.0.38, is the one that fixed the problem, but if you check on the Orbi itself there is a newer version and the newer one seems to have reverted back to the slowdown problem
I do not perform a factory reset after any upgrade anymore. I went through months of troubleshooting with Netgear support and would perform factory resets that would do nothing to change the system's behavior, so I don't bother anymore. It's a waste of time and effort.
The settings that are recorded from you user configuration are simply written to a secure non-volatile memory location on the system and then these locations are read back into the system at boot time to set the configuration. If Netgear is doing a halfway decent job of writing their firmware, doing a factory reset and overwriting these values with default values does nothing but erase your configuration work. There should never be a need to erase these values unless they completely change the configuration memory storage schema. Needing to change the schema is extremely rare as if they have new configuration data that they want to store they can simply tack it on to the end of the existing data using new memory locations.
We, Netgear support and I, checked all kinds of different scenarios and they even replaced the router as part of the troubleshooting process, but nothing pointed us to an environmental problem. I gathered several debug logs for them from when the system was working normally and when it was running slowly and about two or three months later a firmware update was released and the problem went away. I was never notified that a fix was available, so it just be coincidence that the problem went away, but I believe that they were able to identify what was going on and fixed it, but I don't really know for sure.
- FURRYe38Nov 06, 2019Guru - Experienced User
What is the newer version seen on the RBRs FW update page? Just curious here.
Bandito wrote:FURRYe38 ,
- BanditoNov 09, 2019Luminary
FURRYe38 ,
Sorry, I messed up on the firmware version of the RBR50. The current version is the 2.5.0.38, but there was a previous version just prior to this which is the one that corrected my problem. Unfortunately, I don't remember what the previous version number was.
On another note, the RBK852 system is continuing to perform well for me, so it appears to be a keeper!
