brandobot
Mar 12, 2021Guide
Orbi rbk852 extremely slow network after some time
In the furthest room in my house (about 80 ft from the rbr850), wifi signal shows as full bars on my iPhone and Apple Tv that I stream on. Speedtests show around 150 mbps. After half an hour to an ...
Mar 12, 2021Guru - Experienced User
I
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
How are the RBS placed from the RBR? Devices should be connected to the RBS and not the RBR.
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Armor, Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-t-my/m-p/1982974/highlight/true#M7849
- brandobotMar 12, 2021GuideV3.2.16.22
Size of home - 1100 sq ft, single story
Rbr and rbs is at least 40 ft away
Due to my fiber cable location, the router is placed on one end in the house.
How do I make devices connect to only the rbs and not the rbr? About 2/3 of my devices are connected to the rbr.
I’ve disabled 20/40mhz coexistance already.
Will try short preamble next. (Currently on automatic)
I’ve tried auto, and cycled through the different channels manually. Our houses are very spread apart, so shouldn’t have much wifi interference from neighbors.- FURRYe38Mar 12, 2021Guru - Experienced User
Try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
